Ciscoview Install after installation of common services ?
Mar 13th, 2007
I have already installed Common services, Campus Manager, Device Fault Manager and RME. I want to install Ciscoview but it is part of the Common Services install and it want let me install ciscoview without re-installing common services. Is there a way I can install Ciscoview on it's own ?
cheers
Steve
Joe Clarke Tue, 03/13/2007 - 08:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, CiscoView can only be installed as part of Common Services.
unilever01 Tue, 03/13/2007 - 09:22
Thanks for the information. Will I have to de-install all the software then re-install it ? If so how do I backup and restore the current data ?
cheers
Steve
Joe Clarke Tue, 03/13/2007 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you will need to deinstall and reinstall. Use the CiscoWorks backup feature to backup all application data:
NMSROOT/bin/perl NMSROOT/bin/backup.pl
Then, once everything is reinstalled, and patched to the current revision (i.e. what is currently installed on your server), then do the restore:
NMSROOT/bin/perl NMSROOT/bin/restorebackup.pl -d
