CacheEnine as a proxy
Mar 13th, 2007
  • Bronze, 100 points or more
Hi.
Need your help. My customer wants to implement his CE 565 just like a proxy. He will have a private ip on one interface and a public ip on the other interface. Is it possible to have the clients specifying the ip of the CE in their browsers proxy window. If possible, how could i put some restrictions on specific users or ip's.
regards
ZJ
Overall Rating: 5 (1 ratings)
alejrodr Tue, 03/13/2007 - 06:54
  • Cisco Employee,
ZJ,
The CE 565 can be setup as a non-transparent proxy for your users. Please refer to the following link that will explain how this works:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns55/55ldg/exdeploy.htm#wp1103942
Typically, you will use the CE's address as the proxy server's address on your browser's proxy window. You will need to specify a port in order to channel the proxy requests from the users to the CE. 8080 is used by default.
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns55/55ldg/config.htm#wp1412786
Additionally, you can integrate your proxy solution with a authentication and/or URL filtering, where you can have control of users and content going through your CE.
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns55/55ldg/urlfiltr.htm
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns55/55ldg/conauth.htm
Hope if helps.
