Unstable Cisco Aironet 1231
Mar 13th, 2007
I have one Cisco Aironet 1231 access point. It does not use any kind of (server) functionality outside the Cisco device.
I have one SSID and uses WPA-PSK (TKIP).
The configuration seams wary straight forward, but something is wrong.
The access point seams to be unstable. The clients use long time to connect to the access point and it looses connection a lot of times a day. Can I do something to speed up the ?negotiation process? ?
What could be the course of instability?
The configuration was made with the ?web configurator?, but I have a SSH/telnet dump:
Best Regards
Martin
AP1#sh run
Building configuration...
Current configuration : 2227 bytes
version 12.3
no service pad
service password-encryption
hostname AP1
enable secret xxx
clock timezone GMT 1
ip subnet-zero
ip domain name mydom.com
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid myssid
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii xxx
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid myssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.105 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
no cdp run
radius-server local
no authentication leap
no authentication mac
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
sntp server 212.242.xx.207
sntp broadcast client
end
AP1#
scottmac Fri, 03/16/2007 - 17:30
It sounds like interference.
Run NetStumbler (www.netstumbler.com - free) on a laptop and scan the area to see which channel is clearest, and use it.
If you're using Intel NICs/chipsets, make sure they are using current drivers. Some of the older drivers / software are "a little flakey."
Good Luck
Scott
maan449mwa Sat, 03/17/2007 - 11:00
Hi thank you for your answer.
I will try to do a scanning?
But I was thinking, could it have something with the ?hardware negotiation process? to do?
Some time ago I had a cisco switch on a desktop network. The switch missed the line:
?switchport mode access?. If the line is missing the dhcp takes a long time?
On an access-point, is there a ?hardware negotiation process??
Maybe I could turn on ?switchport mode access?, or something else..?
Best regards
Martin
scottmac Mon, 03/19/2007 - 19:12
While there is a negotiation process between the AP and client, it all happens pretty quickly in a typical (i.e., not severely overloaded) system.
The "access port" problem you described was (probably) because of spanning-tree, that should not be an issue here ... the AP is connected to the switch, and the port is active .. all the spanning-tree stuff should have already occurred.
Try a scan. Find the clearest channel of 1, 6, or 11 and configure your AP for that channel and let us know how it works out.
Good Luck
Scott
maan449mwa Thu, 03/22/2007 - 08:48
Now I am using the channel 13, no one is using that one.
After some time the clients still drops the connection for a short time.
(In windows XP I see a "connected to access point" balloon-tip).
It does not disconnect for more that a second, but that is enough time for the program Navision to loose connection completely.
Can I do something I can do to force a network card to stay on access-point?
scottmac Thu, 03/22/2007 - 09:38
Check your client software; many have a "feature" that you can enable/disable for permitting the NIC to powered down by the OS when "idle."
There are some other flavors of "Power Save" mode that might be in-play as well.
Check your drivers, disable any power savers or "sleep" features.
Good Luck
Scott
maan449mwa Mon, 03/26/2007 - 01:33
If I scan the wireless network I see about 20 access-points!!
Should I consider buying a "stronger" antenna?
Maybe this one:
Cisco Aironet High Gain Omnidirectional Ceiling Mount Antenna - Antenne - omni-directional - 5.2 dBi
AIR-ANT1728
Something better?
Best Regards
Martin
scottmac Mon, 03/26/2007 - 07:44
A "stronger" (more gain) antenna probably won't help. An antenna that transmits with more gain also receives with more gain ..(basically, the same situation, but all of the signals are "louder")
The general remedy, aside from the obvious of going to the least populated channel or moving to the 802.11a band, is usually to add more access points, all using some flavor of "sector" antenna (and / or "patch" antennas) to localize the area of interest.
Because the antennas are covering a more specific area (and usually smaller area), it is usually the case that more APs are needed.
"Seeing" 20 APs is not that alarming ... check the signal strength of each, many will usually be well-below the level that would cause serious interference. The specific level will vary, depending on the location relative to the AP<->client relationship.
If you're seeing 20 APs, and their signal strength is roughly the same as your APs or a little lower, then you've got a problem that only a sectorized antenna system can cure.
Good Luck
Scott
