03-13-2007 04:45 AM - edited 02-21-2020 02:55 PM
When I try to install the VPN Client on FC6, I get following errors:
Cisco Systems VPN Client Version 4.8.00 (0490) Linux Installer
In order to build the VPN kernel module, you must have the
kernel headers for the version of the kernel you are running.
Making module
make -C /lib/modules/2.6.19-1.2911.6.5.fc6/build SUBDIRS=/space/home/schulze/installquellen/Cisco/vpn/vpnclient modules
make[1]: Entering directory `/usr/src/kernels/2.6.19-1.2911.6.5.fc6-x86_64'
CC [M] /space/home/schulze/installquellen/Cisco/vpn/vpnclient/linuxcniapi.o
In Datei, eingef?gt von /space/home/schulze/installquellen/Cisco/vpn/vpnclient/Cniapi.h:15,
von /space/home/schulze/installquellen/Cisco/vpn/vpnclient/linuxcniapi.c:27:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/GenDefs.h:110:2: Warnung: #warning 64 bit
CC [M] /space/home/schulze/installquellen/Cisco/vpn/vpnclient/frag.o
von /space/home/schulze/installquellen/Cisco/vpn/vpnclient/frag.c:16:
CC [M] /space/home/schulze/installquellen/Cisco/vpn/vpnclient/IPSecDrvOS_linux.o
In Datei, eingef?gt von /space/home/schulze/installquellen/Cisco/vpn/vpnclient/IPSecDrvOS_linux.c:20:
CC [M] /space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.o
von /space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:30:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c: In Funktion ?handle_vpnup?:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:310: Warnung: Zuweisung von inkompatiblem Zeigertyp
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:334: Warnung: Zuweisung von inkompatiblem Zeigertyp
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:335: Warnung: Zuweisung von inkompatiblem Zeigertyp
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c: In Funktion ?do_cleanup?:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:378: Warnung: Zuweisung von inkompatiblem Zeigertyp
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c: In Funktion ?recv_ip_packet_handler?:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:553: Fehler: ?CHECKSUM_HW? nicht deklariert (erste Benutzung in dieser Funktion)
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:553: Fehler: (Jeder nicht deklarierte Bezeichner wird nur einmal aufgef?hrt
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:553: Fehler: f?r jede Funktion in der er auftritt.)
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:557: Fehler: zu viele Argumente f?r Funktion ?skb_checksum_help?
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c: In Funktion ?do_cni_send?:
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:680: Fehler: ?CHECKSUM_HW? nicht deklariert (erste Benutzung in dieser Funktion)
/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.c:683: Fehler: zu viele Argumente f?r Funktion ?skb_checksum_help?
make[2]: *** [/space/home/schulze/installquellen/Cisco/vpn/vpnclient/interceptor.o] Fehler 1
make[1]: *** [_module_/space/home/schulze/installquellen/Cisco/vpn/vpnclient] Fehler 2
make[1]: Leaving directory `/usr/src/kernels/2.6.19-1.2911.6.5.fc6-x86_64'
make: *** [default] Fehler 2
Failed to make module "cisco_ipsec.ko".
Are there any advices ?
Solved! Go to Solution.
03-19-2007 07:04 AM
There could be various reasons for such a problem:
1) You are missing the kernel source package, which could be checked by running command "rpm -qa | grep kernel". If it is not installed, please grab it from your CD or your favorite Fedora FTP mirror.
2) You could be hitting the bug CSCsc39924. For which the workaround is as follows
In file linuxcniapi.c in the install package, REPLACE THE LINE (2 occurrences):
do_gettimeofday(&skb->stamp);
WITH THE FOLLOWING LINES:
#if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,14)
struct timeval timestamp;
do_gettimeofday(?tamp);
skb_set_timestamp(skb,?tamp);
#else
#endif
AND THEN RUN "vpn_install" AGAIN.
The following links may help you
http://blog.360.yahoo.com/blog-.WURHFYwdq8.zfEosWC6j8jQ?p=55
03-19-2007 07:04 AM
#else
#endif
03-19-2007 04:12 PM
Thats it !!!
Following your hints solved my problem.
Thank you very much
