PDM error
Mar 13th, 2007
Hello, I have installed a FWSM 2.3(4) and when I change a policy for example and I intend to save the config, the PDM shows this error:
"PDM received an error when one or more of the commands below were sent to the FWSM."
Someone could help me please?
Thank you and sorry for my bad English.
hoogen_82 Tue, 03/13/2007 - 12:28
Run the same commands you tried sending through the PDM on the CLI. See what error comes out. Usually should do something with the wrong config statement.
agustinmar Tue, 03/13/2007 - 15:35
Thank you hoogen_82. The problem is that this error is showed in many times, that is, every time that I save the config. Moreover, I think that this problem is generated other problem, since my modules are working with failover and I think that the config isn't copied to the standby module.
Could you help me please?
Thank you for all.
