Cisco 1721 IOS update
Mar 13th, 2007
I have to upload IOS on 1721 router kindly suggest me any link as I have removed the old IOS and copied the new one but never rebooted as want to check 1st from which IOS it will boot
Richard Burts Tue, 03/13/2007 - 06:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Imran
If I understand your post correctly you have already loaded a new version of IOS on your 1721 and have deleted the old image. This should mean that there is a single image in flash. In that case the 1721 will boot from the single image in flash. You can verify this in the output of show flash. There might be some other files in flash but I believe that there would be a single image file.
You might also want to check in the configuration of the 1721 to see if there are any boot system commands in the configuration. If there are any boot system commands you would want to update the boot system commands to point at the new image file that you have loaded.
Rick
imranraheel Thu, 03/15/2007 - 04:08
Well i did wanted to know what commands to use so i will be able to boot the switch in proper IOS
Amit Singh Thu, 03/15/2007 - 04:32
  • Cisco Employee,
Imran,
Do the following:
Check for the IOS in the flash
dir flash:
If you see a valid image file there with the .bin extension, boot the router from there.
boot flash:
once the router is booted set the bootpath to boot from there
router(config)#boot system flash:
If you dont have any image, then you can use TFTPDNLD feature of the router rommon to boot it from TFTP.Please use the link below for mor e info :
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd0e.html
HTH,please rate if it does.
-amit singh
