MPLS Vs Point to Point
Mar 13th, 2007
What are the advantage of using MPLS Vs. Point to Point circuits? I know MPLS offers a Mesh. Are there any other major advantages of using MPLS.
Is QoS better on a MPLS vs Point to Point? It appears to be no difference to me because QoS would just be configured on the router interfaces of a point to point circuit.
All responses are greatly appreciated. Thank You
mheusinger Tue, 03/13/2007 - 08:46
  • Green, 3000 points or more
The answer depends on your requirements.
QoS (here: queueing) is a per interface feature and the encapsulation does not change much. The methods will also be the same (LLQ/CBWFQ).
A MPLS VPN solution offers some advantages, when connectivity between many sites is required AND many customers with overlapping IP addresses are present.
It allows a SP to setup a shared backbone resulting in lower costs per customer.
Depending on your requirements either solution could be best for your network.
Regards, Martin
