WS-X4515
Answered Question
Mar 13th, 2007
the WS-X4515 supports 2 GE ports.
can they be used at the same time, to get redundant links?
Correct Answer by Amit Singh about 10 years 1 month ago
yes, you need to install the GBIC converter on these ports. You have to choose out from WS-5483, WS-5484,WS-5486 GBICs.
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet09186a008014cb5e.html
HTH,please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Amit Singh Tue, 03/13/2007 - 07:59
  • Cisco Employee,
Yes, you can use both the GE ports simultaneously if you are using in a single supervisor config on a chassis. If you are using the Sup engine in a redundant sup engine config on 4507R, only the first port of each sup engine is active. the second port of each sup engine is inactive/standby mode.
-amit singh
