Is this a good way of working :
I plan the following.
I install Two servers : the primary server(A) and a secondary (B) server (so also 2 licenses). A is up and manages the network. The CW on B is down and is used as backup. Every day a backup made on A is copied to B and restored (use start/<restore>/stop). So when A should fail, B can be used to go up. Question : The license on A is also backed up. What about the restore on B. Do I have to do some tricks and save a copy of license B before the restore, to overwrite the resored license.
In other words, will this workflow work?
