Software options for the 3750E and 3560E switches
Mar 13th, 2007
On the data sheets there are image part numbers to order that upgrade from IPBASE to IP Services and Advanced IP Services. The configurator does not have these part numbers as orderable and only offers a standard or enhanced model. How do I get Advanced IP services? The following part numbers are not in the pricing tool.
For the 3750E they are:
3750E-IPS-LIC-B=
IP Services for 3750-E 24 ports, upgrade from IP Base
3750E48-IPS-LIC-B=
IP Services for 3750-E 48 ports, upgrade from IP Base
3750E-AISK9-LIC-B=
Advanced IP Services for 3750-E 24ports, upgrade IP Base
3750E-AISK9-LIC-S=
Advanced IP Services for 3750-E 24ports, upgrade IP Svs
3750E48-AISK9LC-B=
Advanced IP Services for 3750-E 48ports, upgrade IP Base
3750E48-AISK9LC-S=
Advanced IP Services for 3750-E 48ports, upgrade IP Svs
Amit Singh Tue, 03/13/2007 - 08:22
Why do you want to go for ADV IP Services. This has only support for IPV6. If you are not looking for IPV6, then you can upgrade the switch to IP services, which is enhanced image in turn.
-amit singh
srgaskill1 Tue, 03/13/2007 - 08:26
This is for a RFP that is requesting IPv6 Services. Need to have the pricing.
