MPX PBX Integration
Answered Question
Mar 13th, 2007
Has anyone attempted MPX PBX (Avaya) Integration? I looked through the install docs and design guides and unless I am missing something basic I don?t see a clear statement saying MPX with Third Party PBX is supported. We have to do MPX due to cost.
If anyone has tried this please describe your architecture, like did you need a GK etc. If this is not supported can you have a CME tie to an Avaya PBX via PRI or CAS and then MPX integrate to CME and hence Avaya Phones through CME will get to MPX?
Correct Answer by thisisshanky about 10 years 2 months ago
If your PBX supports H323 and ethernet card you can setup a h323 trunk to MPX. Otherwise you can setup a t1 to a router and then have the router setup H323 call to MPX.
Sankar.
Overall Rating: 4 (1 ratings)
Correct Answer
thisisshanky Tue, 03/13/2007 - 10:13
  • Purple, 4500 points or more
Sankar.
skilambi Tue, 03/13/2007 - 10:18
Thanks I was exhanging emails internally but this provides extra validation. I dont think we can H323 on the PBX so the best solution would be Avaya--T1--VG--H323 dial peer--MPX.
Am I right so no need for CME to front end MPX just to integrate with MPX, I can use plain H323 VG to go direct to MPX.
thisisshanky Tue, 03/13/2007 - 10:35
Yes you dont need a CME config in the router. Just dial-peers will do.
