ICM Script File Conversion
Mar 13th, 2007
Does anyone know of a way to convert an ICM script to a Visio, JPEG, or any other picture file?
lpezj Tue, 03/13/2007 - 09:07
There is no way to do it. The only tool that you have in the Script editor is copy the script or some steps of the script as an image. You must select the full script or the part of the script that you would like to copy, go to 'Edit'-> 'Copy Picture'.
In this moment you will have the script image ready to copy to Word, for example.
Hope this helps,
Juan Luis
(Please, rate helpful posts)
Gergely Szabo Thu, 03/15/2007 - 12:02
ICM scripts are stored in the Central Controller database, but if you export them into ICMS, you will notice they have an RTF-like structure. So if you have enough time to kill, you can try to convert that into XML, perhaps and then try to play with them objects...
