Multi-vrf on 3550, 3750
Mar 13th, 2007
i'm in the position on recomending to a friend to use 3550 or 3750 with the multy-vrf feature, but on the feature navigator, it don't show this feature. But i have some 3550 with multi-vrf activate (used as CE for many customers, each with theyr vpn/vrf and a rip process per customer).
This feature in 3550 is not "supported" by Cisco or its not actually "multi-vrf".
thanks
Ciprian
mheusinger Tue, 03/13/2007 - 09:59
  • Green, 3000 points or more
I would say: it is neither "not supported" nor not "multi-vrf" ... it is the feature navigator ;-)
Example: the FN mentions "OSPF Support for Multi-VRF on CE Routers" on the Cat3550 but not "Support for Multi-VRF". If this makes sense to anyone, then please post the explanation :-)
Hope this helps!
Regards, Martin
