show clock rate on DTE?
Mar 13th, 2007
Hi community,
is it possible to see the clock rate configured on the DCE side on the DTE side of a serial interface?
Regards, Martin
kamranraza Tue, 03/13/2007 - 10:15
Yes its possible issue the command:
sh controllers serial x/x/x
on both sides
mheusinger Tue, 03/13/2007 - 10:19
sure on the DCE side this would show the clock rate. But where do you see the clock rate on the DTE side with "show controller"?
Can you post an example?
Regards, Martin
Paolo Bevilacqua Tue, 03/13/2007 - 11:41
Only certain platforms and cards will show the received DTE clock in "show controller". Others will just say "TX and RX clocks detected".
