CCME - Does the 7936 support login/after-hours PIN?
brispin Mon, 03/19/2007 - 11:34
Try the command load phone-type firmware-file .
To associate a type of Cisco Unified IP phone with a phone firmware file, use the load command in telephony-service configuration mode.
you can enable softkeys in ephone-template and associate the template to the ephone later.
