dot1x : IAS x PEAP X 2950 ????
Answered Question
Mar 13th, 2007
Does anybody know, any good how to to implement
that integration ?
cisco 2950 X IAS x PEAP
obs : On wired network
Correct Answer by acomiskey about 10 years 1 month ago
Overall Rating: 5 (2 ratings)
Antonio Brandao Tue, 03/13/2007 - 15:14
thanks acomiskey,
I setup the work with success
but i have a problem to solve...
The client authenticated, but is nothing getting IP address from dhcp server, because the dhcp server is in another vlan and is another network range . follow settings:
dhcp server and ias server (w2k3):
vlan : 10
ip : 192.168.10.100 / 24
client pc (wxp) (after authenticated)
vlan : 20
ip range : 192.168.20.0 /24
guest vlan : 30
what would i do to get dynamic ip from DHCP ?
does have a dhcp server in same vlan and address range of client pc ?
Att Antonio
Antonio Brandao Wed, 03/14/2007 - 08:23
acomiskey,
i included this instructions, but didn't solve the problem...
what can be occurring ?
follow sh rum command attached on post..
obs :
fe 0/9 - my w2k3 server (ad server + ias server + dhcp server)
fe 0/17 - my client pc wXP
fe 0/10 - is a trunk to a linux server, that it's making routing vlan's using.
att
Antonio
acomiskey Wed, 03/14/2007 - 08:57
  • Green, 3000 points or more
Your vlan's appear to be "shutdown".
Antonio Brandao Wed, 03/14/2007 - 09:05
so,
if i set
int vlan 20
no shut
..........vlan 10 that is my up vlan and that a i use to manager the switch goes down !
and after
int vlan 30
no shut
....vlan 20 goes down...
so, the switch 2950 only permit that i have ONE vlan on up state....
Att
Antonio
acomiskey Wed, 03/14/2007 - 09:13
Hmm, you can have multiple vlans active on the switch, but you cannot have multiple vlan interface active at the same time.
acomiskey Wed, 03/14/2007 - 10:59
Are you routing between vlans and if so where? I've never done this on a layer 2 switch, but what's happening is typical of a layer 2 switch. You can only have 1 vlan int active at a time. Where is the default gateway for vlan 20 and 30? We may need someone else's help here.
acomiskey Wed, 03/14/2007 - 11:38
Also, what is this linux server you mentioned?
Antonio Brandao Wed, 03/14/2007 - 12:50
It's a ubuntu linux, loading a package (modeprobe and 8021q) to routing vlan's.
Antonio Brandao Wed, 03/14/2007 - 14:26
acomiskey,
it's working now !!!
i installed the dhcp3-relay package on ubuntu
thanks so much....
Antonio
acomiskey Wed, 03/14/2007 - 14:29
Good deal, that was fun!
