Translating ISDN Simulator Output
Answered Question
Mar 13th, 2007
I am trying to translate the output of our Virtual Console ISDN simulator to identify the telephone number that is being sent out but the messages from our sim do not look right. Can anyone decipher these messages?
PRI:46:04.27 Q931-D-(0)Rx:"0802000A0504039090A21803A183831E0281836C0C21A0333132343332323331307004A1393131"
PRI:46:04.27 Q931-I-(0)SETUP("911")[2]
PRI:46:04.27 Going to connect 0:2(0,000Ah) -> 0:0(1,8001h) 3.1kHz audio
PRI:46:04.27 Q931-D-(0)Tx:"0802800A021803A98383"
PRI:46:04.27 Q931-D-(0)Tx:"080200010504039090A21803A983816C0C21A0333132343332323331307004A1393131740480393131"
PRI:46:04.38 Q931-D-(0)Rx:"08028001021803A98381"
PRI:46:04.38 Q931-I-(0)CALL PROCEEDING
PRI:46:04.38 Q931-D-(0)Tx:"0802800A02"
PRI:46:04.39 Q931-D-(0)Rx:"080280014508028191"
PRI:46:04.39 Q931-I-(0)DISCONNECT
PRI:46:04.39 Q931-D-(0)Tx:"0802800A4508028191"
PRI:46:04.48 Q931-D-(0)Rx:"0802000A7D080381E202140103"
PRI:46:04.48 Q931-I-(0)STATUS
PRI:46:04.52 Q931-D-(0)Rx:"0802000A4D"
PRI:46:04.52 Q931-I-(0)RELEASE
PRI:46:04.52 Q931-D-(0)Tx:"080200014D"
PRI:46:04.52 Q931-D-(0)Tx:"0802800A5A"
PRI:46:04.58 Q931-D-(0)Rx:"080280015A"
PRI:46:04.58 Q931-I-(0)RELEASE_COMPLETE
Correct Answer by jgolia about 10 years 2 months ago
Read Between the Threes! :)
Correct Answer by paolo bevilacqua about 10 years 2 months ago
looks to that 312 432 2310 is calling 911.
Hope this helps.
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Tue, 03/13/2007 - 15:07
  • Hall of Fame,
    Founding Member
Hope this helps.
jmaduncan Wed, 03/14/2007 - 06:15
Yes, that is very helpful, thank you. But how can I translate the output? How is it encoded?
Correct Answer
jgolia Wed, 03/14/2007 - 07:50
jmaduncan Wed, 03/14/2007 - 08:00
Thanks, I figured it out right before you answered. I am a bit embarrased that I didn't notice it before now. Is the number 3 a standard spacer for ISDN?
paolo bevilacqua Wed, 03/14/2007 - 09:58
  • Hall of Fame,
    Founding Member
No. What you see is hexadecimal representing the string. The numbers are coded in ascii, so 30=0, 31=1, and so forth.
Thanks for the rating!
