Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927389members
1240071discussions
Community Activity
Router 1721 not saving Config
Hi Guys a quick one, I have a problem with my router which is not saving configuration after I switch off. Where do I go ? Any clues
cm by Level 1
  • 1769 Views
  • 5 replies
C9800-80 in HA cannot install APSP6
Hello everyone,I'm trying to figure out a frustrating issue. Attempting an install of APSP6 keeps bombing out and I'm unsure what steps to take next. Software: Version 17.09.04aROM: 17.3(3r)Error in question:  Dec 13 21:21:01 Eastern: %INSTALL-3-OPER...
Cisco AnyConnect Umbrella Roaming Security Module
Hi,So was reading up a lot on the difference between the Cisco Anyconnect Roaming Module vs the Umbrella Roaming,Its clear that best practice is the Cisco anyconnect option as UR is EOL in a few months, so we recently deployed the new client company ...
Cisco Packet Tracer 2960-24TT indicates Orange (amber)
Hello everyone. I work in Cisco Packet Tracer and have a simple network with 5 subnetworks connected through 2960-24TT Switch. The problem is when i connect 5 subnetworks to 1 network some (3) routes light orange (amber). And i can`t fix it. Where sh...
ASA5506-X simple setup NOT understanding HELP
I’m not sure if I’m posting this in the right spot; I’m new to this needing help with setup of a device. I’ve been trying and failing at setting up my 5506. I have a few questions I think if I can get cleared up I can maybe get this working. Please h...
Hide Finesse Gadget Header/title
Hi, I'm trying to hide the "Supervisor Assist Gadget" title for the Finesse 3rd party gadget. In the gadget xml, I removed the title by which I was able to hide the gadget title and the text moved up to where the title is but now I'm getting empty s...
1d3999d0-d301-4988-a26f-3105aff6f980.jpg bbc85726-c204-47e4-8f3b-629c64062a5e.jpg
SakethN by Level 1
  • 109 Views
  • 1 replies
CS-DESKPRO-K9++ USB Control
Can I use a RS232/serial to USB converter to control the Cisco CS-DESKPRO with Crestron control? The Cisco Deskpro doesnt come with an RS232/serial port. Controlling to Ethernet is not an option for the project i am working on.
jvputian by Level 1
  • 37 Views
  • 0 replies
IPv6 ping not working when pinging other LAN
I configured the simple network below to test the connectivity of the ipv6 in the devices. The configurations are as shown and ipv6 unicast-routing is enabled. When pinging from Router 5 to Router 6 G0/1, it succeeds but when pinging from Router 5 to...
abandoned call to agent timer
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 155 Views
  • 3 replies
