PLAR on Call Manager
Mar 13th, 2007
I'm attempting to set up a direct PLAR to a line appearance on 79XX sets. I would like to have the FXO ring the line appearance, (I get this piece working)but I'm unable to access the line on the 7960 in this case and draw dialtone from the FXO. I would like to go directly to the FXO without the need for a dial pattern. Is there a way to achieve these results on Call Manager? I'm running 4.13(es94)version 4.1(0.11) Any help thoughts accepted and appreciated.
Overall Rating: 4 (1 ratings)
Brandon Buffin Wed, 03/14/2007 - 16:56
The FXO trunk line functionality is availabe with Callmanger Express, but not with Callmanager. You can give the appearance of this functionality by doing the following.
1. Create a speeddial on the phone of 9.
2. Go to Callmanager service parameters and change the Speed Dial Await Further Digits parameter to True.
Now the user can begin dialing the number when they choose this "line". Of course the route patterns will still have to be in place, but it gives the appearance of seizing a line.
Hope this helps. If so, please rate the post.
Brandon
