Address determined by ???
wessam.sadek
i have a problem in some vlan and i am asking what is the different between (Address determined by setup command VS Address determined by non-volatile memory)
as you see in the sh ip int br
all vlan method is nvran but only the 71 and 110 is manual so can any one hel say to me how can i change it and what is this address determined ?
Vlan1 unassigned YES NVRAM administratively down down
Vlan5 10.0.0.1 YES NVRAM up up
Vlan10 10.0.10.1 YES NVRAM up up
Vlan11 10.0.11.1 YES NVRAM up up
Vlan20 10.0.20.1 YES NVRAM up up
Vlan21 10.0.21.1 YES NVRAM up up
Vlan30 10.0.30.1 YES NVRAM up up
Vlan31 10.0.31.1 YES NVRAM up up
Vlan40 10.0.40.1 YES NVRAM up up
Vlan41 10.0.41.1 YES NVRAM up up
Vlan50 10.0.50.1 YES NVRAM up up
Vlan51 10.0.51.1 YES NVRAM up up
Vlan60 10.0.60.1 YES NVRAM up up
Vlan61 10.0.61.1 YES NVRAM up up
Vlan70 10.0.70.1 YES NVRAM up up
Vlan71 10.0.71.1 YES manual up up
Vlan80 10.0.80.1 YES NVRAM up up
Vlan81 10.0.81.1 YES NVRAM up up
Vlan90 10.0.90.1 YES NVRAM up up
Vlan91 10.0.91.1 YES NVRAM up up
Vlan100 10.0.100.1 YES NVRAM up up
Vlan110 10.0.110.1 YES manual up up
Vlan120 10.0.120.1 YES NVRAM up up
--More--
Richard Burts
wessam
When the output indicates NVRAM it is indicating that the interface address configuration was previously configured, saved to NVRAM, and was read from NVRAM at bootup. When it indicates manual it is indicating that you have manually configured this interface since the last time that the router booted.
If you really want to change it, save the config to NVRAM (startup-config) and reboot the router. I do not believe that it will change anything that impacts what you are doing or any problem that you may be experiencing.
Rick
Rick
dear rburts;
thanks for your reply but i had configure this vlan and reboot the switch 4500 many time and it dint get from nvram so can you please advise
