XML Config Example
Answered Question
Mar 13th, 2007
Can someone send me an example of posting XML commands to the CSM? For example setting a real to 'no inservice'.
Thanks!
Correct Answer by Syed Iftekhar Ahmed about 10 years 2 months ago
curl -v -H Connection:close -u cisco:cisco -d @filename 10.10.10.10/xml-config
where
10.10.10.10 is CSM IP
-v will print messages between device & CSM
-H is used to specify extra header
-u to specify user & password
hope it helps
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Tue, 03/13/2007 - 16:03
  • Blue, 1500 points or more
A simple XML file that would enable a real in Serverfarm will be
<?xml version="1.0" ?>
Then, to take the real out of service would be:
Hope it helps
Syed Iftekhar Ahmed
lfrc8554 Tue, 03/13/2007 - 20:09
Syed,
This is great...
Would you also know how to format this post with curl?
Correct Answer
Syed Iftekhar Ahmed Wed, 03/14/2007 - 02:04
where
hope it helps
Syed Iftekhar Ahmed
