lpezj Wed, 03/14/2007 - 07:51
  • Gold, 750 points or more
try to look in this directory:
C:\Program Files\wfavvid\scripts
You could see three directories and there are stored all the '.aef' scripts files.
Hope this helps,
Juan Luis
xiaoliangyue Wed, 03/14/2007 - 09:02
Thanks Juan.
I thought the scripts should be there. However, after a scripts was uploaded, I searched all hard drives, they can't be found.
mstoychev Wed, 03/14/2007 - 14:03
The scripts uploaded in IVR/CRS/IPCC Express are in the repository - ldap.
You can access them using the web admin in script management section or using the script editor (4.0) looking in the repository ( not on the disk). Yu can look in the docs if you don't know how to use these tools. I hope it helps.
