Wireless VLAN help
Mar 13th, 2007
We have two wireless devices both with two radios installed. Dot11Radio1 is used for our bridge and the other radio is used for wireless users. My problem is that I have two VLANS, vlan 100 is for data traffic and mgmt traffic, and vlan 200 is for my voice traffic. I can only seem to get VLAN 200 to communicate over this bridge connection based on my output of sho dot11 association. With the attached configuration I cannot ping anything on VLAN 100 on remote bridge, and users at this remote cannot get to the internet.
ap1.hostbridge#sho dot ass 0019.079b.0100
Address : 0019.079b.0100 Name : ap2.remotebridge
IP Address : 192.110.235.119 Interface : Dot11Radio 1
Device : 11a-bridge Software Version : NONE
CCX Version : NONE
State : Assoc Parent : self
SSID : wirelessphones VLAN : 200 <----
Hops to Infra : 1 Association Id : 6
Clients Associated: 0 Repeaters associated: 0
Tunnel Address : 0.0.0.0
Key Mgmt type : NONE Encryption : WEP
Current Rate : 54.0 Capability : WMM
Supported Rates : 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates : disabled
Signal Strength : -70 dBm Connected for : 778 seconds
Signal to Noise : 28 dBm Activity Timeout : 30 seconds
Power-save : Off Last Activity : 0 seconds ago
Apsd DE AC(s) : NONE
Packets Input : 2086 Packets Output : 2044
Bytes Input : 190223 Bytes Output : 275211
Duplicates Rcvd : 0 Data Retries : 0
Decrypt Failed : 0 RTS Retries : 0
MIC Failed : 0 MIC Missing : 0
Packets Redirected: 0 Redirect Filtered: 0
When I try to add the VLAN 100 SSID under the Dot11Radio1 interface the remote bridge deauthenticates on vlan 200 SSID, and no more connectivity. Also the Virtual interfaces go down down.
I am trying to connect both VLAN 100 and VLAN 200 over this bridge connection, but it doesn't seem to work. What am I missing?????
Rob Huffman Wed, 03/14/2007 - 07:09
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Glen,
I have never done much with bridging so I don't know if this helps :( But I did come across this good doc that discusses the config of Multiple vlans in a bridging environment;
VLANs on Bridges
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml#vlanbr
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
