Wanna track CRC Error?
Answered Question
Mar 13th, 2007
I wanna track CRC Error..Understand I can use MIBs object? But any links to point me to the config? Or any advises on this?
Thanks!
Correct Answer by kyawzawhtut about 10 years 3 months ago
I am not sure CRC error is similar to packets errors.
You can use CiscoWorks LMS to send notification if line error rate is greater than certain %(1% is default).
I do not see any point to track the exact figure as it is ever growing if I remember correctly.
Ask you customer what will they do with the figures? Most important thing is to get alerted when error rate is high not because of 1 crc error out of millions of packets.
HTH.
Plz rate if helpful.
Kyaw
Overall Rating: 5 (1 ratings)
rajivrajan1 Tue, 03/13/2007 - 22:14
  • Bronze, 100 points or more
If u can explain in detail, we can try something
cindylee27 Wed, 03/14/2007 - 18:43
Hi Rajiv,
Now the customer wants to track CRC Error of the interface..so I need to get update like one day, on this interface how many CRC Errors I got from INterface0/0,etc etc..
Can I able to track from a server software or how can I do it?
Thanks!
Correct Answer
kyawzawhtut Thu, 03/15/2007 - 00:57
HTH.
Kyaw
