IPCC CRS 4.0.4 installation issue: it keeps running SQLUtilites
Mar 13th, 2007
IPCC CRS 4.0.4 installation finished. Not any error during the OS/IPCC installation.
(hasn't installed service release yet)
while I configure IPCC, It keeps running SQLUtilites installation program.
Anybody has any idea?
2 IPCC servers(1 primary, 1 standby), same situation)
Overall Rating: 4 (1 ratings)
adignan Wed, 03/14/2007 - 05:19
This is fixed in a 4.0(5). Its just cosmetic so you can ignore it for the short term.
please rate helpful posts.
master001 Thu, 03/29/2007 - 12:35
Hi thank you for your reply.
The IPCC server works now, though we haven't upgrade to 4.0(5).
daljeetsingh1_2 Tue, 04/17/2007 - 05:48
Do you know how you got rid of this?
I have same setup and same version and i have the same SQLutility issue.
Thanks in Advance!
JASON WELCH Thu, 01/31/2008 - 09:54
We have the same issue: CRS4.04sr1 with HA. What I finally resorted to was downloading a copy of msconfig.exe and editing the startup programs. The SQLUtility is the "UpdateUtility". I disabled that from running at startup. This is just a bandaid fix, but TAC wasnt' able to provide me with a better solution to get the SQLUtility to stop running at startup. We're in the process of upgrading to UCCX5.0 now so it will be a null issue for us....hopefully.
