ahmednaas Tue, 03/13/2007 - 23:47
  • Silver, 250 points or more
I just tried this on a 3560 running the advanced ip services image:
C3560PoE>en
Password:
C3560PoE#conf t
Enter configuration commands, one per line. End with CNTL/Z.
C3560PoE(config)#ip nat ?
% Unrecognized command
So it seems NAT is not supported. Also a search of the "Catalyst 3560 Switch Software Configuration Guide.pdf" did not produce any refrences to configuring NAT.
