Which IOS for 7301 and 7204 to support MPLS?
Mar 14th, 2007
Hi all,
I have two routers Cisco that run BGP4 now. I want to use MPLS in the core network. Please tell me which IOS for my routers to support MPLS and its ok for router hardware
R_LNS1#sh version
Cisco IOS Software, 7301 Software (C7301-IS-M), Version 12.3(8)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 10-Aug-05 20:38 by dchih
ROM: System Bootstrap, Version 12.2(8r)B3a, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7301 Software (C7301-BOOT-M), Version 12.3(8)T4, RELEASE SOFTWARE (fc2)
R_LNS1 uptime is 35 weeks, 1 day, 14 hours, 33 minutes
System restarted at 22:34:55 CET-DST Mon Jul 3 2006
System image file is "disk0:c7301-is-mz.123-8.T11.bin"
Cisco 7301 (NPE) processor (revision C) with 983040K/65536K bytes of memory.
Processor board ID 74811033
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
1 slot midplane, Version 3.0
Last reset from power-on
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
32768K bytes of Flash internal SIMM (Sector size 256K).
lo-bgp4#sh version
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(5a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 14-Jan-06 00:25 by alnguyen
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(5a), RELEASE SOFTWARE (fc3)
lo-bgp4 uptime is 5 weeks, 1 hour, 4 minutes
System restarted at 10:17:51 UTC Wed Jan 31 2007
System image file is "disk2:c7200-is-mz.124-5a.bin"
Cisco 7204VXR (NPE-G1) processor (revision A) with 983040K/65536K bytes of memory.
Processor board ID 25859009
4 slot VXR midplane, Version 2.5
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 300 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 ATM interface
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Thanks for your helping
emaamur2006 Wed, 03/14/2007 - 04:16
you can use any of these
c7200-k91p-mz.122-25.S9.bin
c7200-js-mz.122-25.S10.bin
c7200-adventerprisek9-mz.124-4.T1.bin
You can also use the Software advisor on CCO to get the right IOS for your Product
BR
Emaamur
intermediasud Wed, 03/14/2007 - 07:05
Thanks for your reply
I found two IOS on the CISCO but i don't know its ok for my hardware or not ?
c7200-g4js-mz.124-13 for 7200
c7301-g4js-mz.124-13 for 7301
Anyone can tell me the procedure to change IOS in the router ?
