Content rule Content CSS 11 500 question
Mar 14th, 2007
I have the following question, the port number in a content rule is this the port to witch the content switch forwards or to witch he listens on.
Suppose i have an url www.myname.org
when i receive this on the content switch i want to redirect it to the backend on port 8080. How can i do this.
Gilles Dufour Wed, 03/14/2007 - 03:13
inside the content rule, the port command indicates the port the CSS listens on.
If you want to forward the connection to a different port, you have to configure it inside the service using the port command as well.
Gilles.
alejrodr Wed, 03/14/2007 - 15:54
Frederik,
A quick example of what you are trying to do is this:
Service Server1
ip address z.z.z.z
port 8080 <-- Port for backend server
active
owner myname.org
content L5_HTTP
vip address x.x.x.x
port 80 <-- Port rule is listening on
add service Server1
add service Server2
add service Server3
active
Hope it helps.
Frederik1980 Thu, 03/15/2007 - 04:23
For example we have the following rule.
service server1
port 40918
ip address 10.2.48.131
keepalive frequency 20
keepalive retryperiod 60
keepalive type tcp
keepalive port 40918
redundant-index 110
active
content rulename
vip address 10.5.1.1
redundant-index 114
balance leastconn
add service server1
add service server2
add service server3
add service server4
protocol tcp
port 40918
url "//domain.be/*"
active
I don't realy understand this rule. Especially the url "//domain.be/*
How will processing this content rule work? First match DNS name?
alejrodr Thu, 03/15/2007 - 06:21
Frederik,
Your content rule is what we call a Layer 5 Content Rule since it has a HTTP URL field in its matching criteria.
This means the CSS will be listening for traffic that is heading towards VIP Address 10.5.1.1 on port 40918 AND that it matches a certain URL. This URL in your case is "//domain.be/*".
When traffic is initiated to VIP 10.5.1.1, the CSS will use Layer 5 information such as the URL included in the client requests to match the traffic to this content rule.
When you use a browser to access this desired page, your DNS will probably return 10.5.1.1 for domain.be, telling your browser to make a request to VIP 10.5.1.1 and URL "//domain.be/*".
Please take a look at this link for more information.
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_820/cntlbgd/contrule.htm#wp1037654
Hope it helps.
