CW LMS 2.6 - Can I monitor routers?
Answered Question
Mar 14th, 2007
Dear Support,
Sorry quick (hopefully) question, but need to check I don't need to purchase the RWAN products as well.
We have a HQ site with 6 switches and two 2621xm routers, and a datacentre site with 6 switches and two 2621xm routers. Can I monitor all these devices through LMS, even though the DC has several subnets and is the other side of the routers?
thanks in advance.
I always rate helpful posts.
regards, Adrian
Correct Answer by drolemc about 10 years 4 months ago
I think you should be able to monitor all of the devices as LMS 2.6 includes RME which keeps the inventory of all the devices, although certain functionalities will be restricted for management of remote devices.
Following links may help you
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_qanda_item0900aecd80532fc7.shtml
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html
Overall Rating: 5 (1 ratings)
Correct Answer
drolemc Tue, 03/20/2007 - 06:55
  • Silver, 250 points or more
