Connection to H323 service provider
Mar 14th, 2007
I need to connect CCM to h323 service provider. I have 2811 (c2800nm-ipvoice-mz.124-13a.bin) which is connected to h323 provider. I need to know what configuration i must do on 2811 and what to do on CCM. Thx in advance.
Overall Rating: 4 (1 ratings)
jgolia Wed, 03/14/2007 - 04:58
Try this link for an overview of IP-IP Gateway. It is titled Cisco CallManager to H.323 Service Provider Connectivity.
You will then need to simply add the H323 GW into CCM. Don't forget to Bind your H323 signalling to a specific address. Also replace your default inbound voip dialpeer.
Please rate helpful posts.
Paolo Bevilacqua Wed, 03/14/2007 - 10:13
only think jgolia hasn't mentioned in his good advice, is that you also need a different image (the IP-to-IP gateway one) on the 2811. These image names ends in _ivs. Cisco requires a license too.
The alternative is to enable direct IP communication between CCM and the h323 service provider.
