CSS Load Balancing Citrix Terminal server, is ti possible ?
Mar 14th, 2007
Hi we have to balance a Terminal Server Citrix Server Farm with css, did anyone already realize it? Is there any problem to do it ? Someone told me there is nat problem with citrix metaframe terminal server, has anyone information about it ?
Any help will be greatly appreciated. Many thanks
e-dennington Tue, 03/20/2007 - 08:43
Are you having issues once you are balanced to one of your citrix servers? Make sure you configure stickyness so that users remain stuck to the initial server they are load balanced to. This is needed due to the fact that each connection is not stateful between citrix servers.
e-dennington Tue, 03/20/2007 - 11:50
Stickyness means that once a user is directed to a server through the load balancer, that user will remain on the server he was first load balanced to for the duration of their connection. Otherwise, every tcp connection that a user makes is load balanced to whatever servers are configured. There are severalways to configure stickyness. You can do it via:
-source IP
-source IP and destination port
-text string in a cookie or URL
-SSL session ID
take a look at this document that explains it better than I could:
