QOS : Vlan based 6500
Mar 14th, 2007
I have a doubt about my config on a IOS 6500 for Voice QOS :
sup 2
interface config :
interface Vlan323
description IPT
bandwidth 100000
service-policy output QosVoice
Policy config :
show policy-map QosVoice
Policy Map QosVoice
class QosVoice
priority percent 10
class QOSdefault
bandwidth percent 89
lass Map match-all QosVoice (id 3)
Match ip dscp 46
DSCP 46 is mapped to COS 5
Physical interface :
interface GigabitEthernet4/2
description Smals LB
logging event link-status
load-interval 30
speed 100
duplex full
udld port
mls qos vlan-based
mls qos trust dscp
What is strange is that no packet are
flagged on the show policy-map.
A show interface Gig4/2 show fifo queueing.
But a show queueing int gig 4/2 shows wrr + pq
Any help would be greatly appreciated.
Luc
mheusinger Wed, 03/14/2007 - 04:57
show policy-map will just display the configuration. "show policy-map interface" will give you QoS statistics. But also be aware, that not every packet may show up though if it is cef switched and the interface is not overloaded. Have a look at
"Understanding Packet Counters in show policy-map interface Output"
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
Hope this helps!
Regards, Martin
csco10387876 Thu, 03/15/2007 - 02:14
Thanks Martin,
What I don't get is why the queueing method showed is different with show interface and show queueing ?
Thanks again,
Luc
