Mutlilink PPP help.
Mar 14th, 2007
Hello all,
I have two sight for internet traffic which are connected with two T1's. I configure them with multilink ppp so i should get a throughput of 3 Mbps correct? My snmp traffic graph is not showing a balanced load across the two T1's. Here are the router configs:
Router1:
interface Multilink1
ip address 69.X.X.X 255.255.255.252
no ip mroute-cache
no cdp enable
ppp multilink
multilink-group 1
interface FastEthernet0/0
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
interface Serial0/0
no ip address
encapsulation ppp
no fair-queue
pulse-time 10
no cdp enable
ppp multilink
multilink-group 1
interface FastEthernet0/1
ip address 69.X.X.X 255.255.255.128
speed 100
full-duplex
interface Serial0/1
no ip address
encapsulation ppp
no fair-queue
pulse-time 10
ppp multilink
multilink-group 1
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 69.X.X.X 255.255.255.192 69.X.X.X
ip route 208.X.X.0 255.255.255.128 X.X.X.X
Router 2 (remote site):
controller T1 0/0
framing esf
clock source line primary
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 0/1
framing esf
clock source internal
linecode b8zs
controller T1 1/0
shutdown
framing esf
linecode b8zs
controller T1 1/1
shutdown
framing esf
linecode b8zs
controller T1 1/2
shutdown
framing esf
linecode b8zs
controller T1 1/3
shutdown
framing esf
linecode b8zs
no ip mroute-cache
no cdp enable
ppp multilink
ppp multilink group 1
ip address 69.X.X.X 255.255.255.192
speed 10
half-duplex
interface Serial0/0:0
no ip address
encapsulation ppp
no fair-queue
pulse-time 10
ppp multilink
interface Serial0/1:0
no ip address
encapsulation ppp
no fair-queue
pulse-time 10
ppp multilink
interface Serial1/0:0
no ip address
shutdown
interface Serial1/1:0
no ip address
shutdown
interface Serial1/2:0
no ip address
shutdown
interface Serial1/3:0
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 69.X.X.X (Multilink IP address of router 1)
Can anyone tell me what I'm doing wrong?
Overall Rating: 5 (1 ratings)
Amit Singh Wed, 03/14/2007 - 07:36
  • Cisco Employee,
MLPPP makes sure that there is an equal packet distribution acorss the links.
By default the router does per destination load-balancing on the interfaces. If you want to do per-packet load-balancing, you can disable fast switching on the serial interfaces by using "no ip route-cache".
If you have CEF enabled on the router, you can also use CEF to do that load-blancing per packet. under the interface use " ip cef load-balncing per-packet".
Try the above to options listed above and see if it helps.
-amit singh
ktcisg@kaplantel.net Wed, 03/14/2007 - 07:41
I am now seeing that the two circuits are balanced. However, I am not sure that I am getting the best throughput. Is there any way to test this? Thanks.
Amit Singh Wed, 03/14/2007 - 07:56
  • Cisco Employee,
"I am now seeing that the two circuits are balanced",Please tell us the configuration you did. You can check it only in the reporting graphs or under the serial interface using " show interface" command and should show you almost equal traffic pattern.
-amit singh
ktcisg@kaplantel.net Wed, 03/14/2007 - 07:58
The configuation is list above. When I do a speed test (speakeasy.net) I would expect to see at leat a 2 to 2.5 Mbps throughput, however the highest I have gotten was 1690 with very little usage on the two circuits.
