Amit Singh Wed, 03/14/2007 - 07:45
  • Cisco Employee,
What happens when you try to access flash using " dir flash:"
Do you access it and see any file in there?
-amit singh
tontonkab Wed, 03/14/2007 - 08:17
I do but show me that there is a file name like startup-configt instead of c1700-mz...bin
nothing in all confreg setting
spremkumar Wed, 03/14/2007 - 23:36
  • Red, 2250 points or more
can you try giving boot command under the rommon prompt.
Once you are done it should boot normally and get you to the router prompt.
Once you are there in the router prompt you can check out for the confreg and change the same..
regds
