VPN Client Says "status: Disconnected"
vmbhatia2 Sun, 03/18/2007 - 01:59
Which operating system are you using ? Does the client work with other systems running on the older OS ?
If you are using Vista, you must goto http://www.cisco.com/cgi-bin/tablebuild.pl/windows
and download vpnclient-win-msi- (CCO Access Required)
If you are using windows, you must also see if the Cisco Systems Virtual VPN adaptor is installed in your network connections successfully.
Hope this helps in some way.
