03-14-2007 08:52 AM - last edited on 03-25-2019 03:54 PM by ciscomoderator
I have a customer who had a frame relay circuit that we were doing frame relay traffic shaping on. The voice quality between the two sites worked fine. They currently switched to a frame-relay mpls system offered by Bellsouth.
The voice quality is very bad now because of this. Can anyone see anything wrong with the config?
class-map match-all VoIP-Ingress
match access-group 100
class-map match-all VoIP-Egress
match ip dscp ef
policy-map QoS-Egress-WAN
class VoIP-Egress
priority percent 50
police cir percent 50
conform-action transmit
exceed-action transmit
class class-default
policy-map QoS-Ingress-LAN
class VoIP-Ingress
set ip dscp ef
class class-default
set ip dscp 0
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.192
service-policy input QoS-Ingress-LAN
speed 100
full-duplex
interface Serial0/0
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-8
frame-relay lmi-type ansi
max-reserved-bandwidth 100
service-policy output QoS-Egress-WAN
interface Serial0/0.1 point-to-point
ip address x.x.x.x 255.255.255.252
frame-relay interface-dlci xxx
interface FastEthernet0/1
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
03-14-2007 10:20 AM
I would change some things:
match ip dscp ef
class VoIP-Egress
priority percent 50
class class-default
fair-queue
class VoIP-Ingress
set ip dscp ef
class class-default
set ip dscp 0
speed 100
full-duplex
interface Serial0/0
no ip address
frame-relay traffic-shaping
bandwidth 512
class FR
duplex auto
speed auto
map-class frame-relay FR
frame-relay cir 512000
frame-relay fragment 900
The output policy-map should be applied to the IP interface. Check with "show policy-map interface", if you have any matches in the voip class - before and after the changes. Also do not police voip, which could lead to unwanted drops even if the bandwidth is not used for other traffic.
I also applied LFI to reduce the jitter (fragement size 900).
I am assuming your ACL 100 grabs the voip traffic ...
Finally, make sure the SP also applies QoS to his end of the FR PVC and throughout the MPLS cloud.
Hope this helps!
Regards, Martin
05-17-2007 03:22 PM
Not sure about this.
I am not able to apply the 'class' command under the DLCI once I have put 'frame-relay traffic-shaping' in the main interface.
I think the map class would need to be applied to the sub-interface using 'frame-relay class FR'
05-17-2007 11:36 PM
I just want to add to Martin's fabulous explaination, that i've been to a case where when applying the policy-map under the map-class frame-relay it didn't work, and then when applying it under the serial subinterface it worked fine, and i thought that it is an IOS bug.
HTH,
Mohammed Mahmoud.
05-19-2007 04:17 AM
HELP!
Can anyone explain this please?
Thanks for your reply Mohammed. I thought I was going crazy.
