CCM 4.1 to 5.0 Upgrade
Answered Question
Mar 14th, 2007
I have a customer currently running CCM 4.1. They have just purchased Unified Call Manager 5.0 appliance. Does anyone know if it is possible to use DMA to get the existing database off the CCM 4.1 server and to import it onto the new appliance? Any help or suggestions for a successful upgrade would be very much appreciated.
Tracey
Correct Answer by Rob Huffman about 10 years 2 months ago
Hi Tracey,
Yes, you should be just fine with using DMA for the 4.1 to 5.1 process. Have a look;
DMA migrates data for Cisco Unified CallManager and Cisco Emergency Responder, as specified in the following sections.
DMA assists you with the first step in migrating Cisco Unified CallManager data from versions 4.0(x) and 4.1(x) to Cisco Unified CallManager 5.1(1) by backing up this data in a format that Cisco Unified CallManager 5.1(1) can read. Cisco Unified CallManager 4.1(x) runs in a Windows environment, and Cisco Unified CallManager 5.1(1) runs in a Linux environment, so DMA exports Windows-based data to a format that Linux can import. The Cisco Unified CallManager 5.1(1) installation process converts the backed up data as needed for Cisco Unified CallManager 5.1(1), which completes the data migration.
DMA saves the data that it exports in a tape archive (TAR) file in a location that you specify.
You must install and run DMA on the Cisco Unified CallManager publisher server before you upgrade to Cisco Unified CallManager 5.1(1). If you make any Cisco Unified CallManager configuration changes after running DMA, the system does not retain these changes when you upgrade.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_upgrade_guides09186a0080792e77.html#wp37259
Cisco Unified CallManager Documentation Guide for Release 5.1(1)
At this location;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_documentation_roadmap09186a008076f99b.html
Hope this helps! CCM 5.1 may also be a better choice here anyways :)
Rob
Overall Rating: 5 (3 ratings)
thisisshanky Wed, 03/14/2007 - 09:21
  • Purple, 4500 points or more
Tracey,
You can run DMA to migrate the database to 5.0. These steps may help.
a. Take BARS backup of existing publisher
b. Install Callmanager Upgrade utility and run it until all errors are fixed
h. Install DMA (latest version) ? This will need to match up with the version of 5.0 you are installing. If CM 5.0 version is 5.0(4), then download DMA version 5.0(4)
i. If DMA throws out errors, you may have to call TAC (1-800-553-2447)
j. DMA outputs the database into a tar file. Store this tar file in a usb drive or in a server that can run SFTP or FTP
k. Install 5.0 on the new server and in the wizard, select Windows upgrade. This will let you specify the ip address of remote SFTP or FTP server and data location and pull the tar file down.
l. The 2 nodes (publisher and subscriber) and the phone counts (converted into DLUs) will show up in the License Unit report page in Callmanager after the upgrade.
m. This license file needs to be sent to Cisco licensing ([email protected]) along with mac address of publisher to get a new permanent license.
Sankar
PS: please remember to rate posts!
Rob Huffman Wed, 03/14/2007 - 09:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Tracey,
I just wanted to add a few good docs to Sankar's excellent notes;
Upgrading Cisco Unified CallManager Release 5.0(4)
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a00806c3cc3.html
Data Migration Assistant User Guide Release 5.0(4)
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide09186a00806c51d6.html
Cisco Unified CallManager System Guide, Release 5.0(4) - Licensing
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806b036f.html#wp1100548
Hope this helps! And best of luck.
Rob
tracey.marshall Wed, 03/14/2007 - 10:02
Thanks to you both for the prompt replies and extremely useful information. I am carrying out the work next week and now feel more confident.
Many thanks once again,
Tracey
thisisshanky Wed, 03/14/2007 - 11:32
Tracey,
Good luck on the migration and thanks for the 5.
tracey.marshall Mon, 03/19/2007 - 07:28
Just unpacked my new call manager 5 to discover that it is version 5.1 and not 5.0, which was on the equipment list I received. Unfortunately, the readme file link for DMA51 actually takes me to the release notes for CCM5.1. I am trying to find out if I can upgrade from 4.1 to 5.1 using DMA.
Any help and advise would be greatly appreciated.
Many thanks,
Tracey
Correct Answer
Rob Huffman Mon, 03/19/2007 - 07:43
  • Hall of Fame,
    Founding Member
Hi Tracey,
From this doc;
At this location;
Rob
tracey.marshall Mon, 03/19/2007 - 07:54
Hi Rob,
Thanks so much for helping me out again! The documentation roadmap seems to have everything I need.
Many thanks, once again.
Tracey
Rob Huffman Mon, 03/19/2007 - 08:22
  • Hall of Fame,
    Founding Member
Hi Tracey,
You are most welcome! Best of luck with your planned upgrade, let us know how you make out.
Take care,
Rob
tracey.marshall Mon, 03/19/2007 - 08:36
Thanks Rob. I have not got off to a good start. I have an MCS-7835-I2. When I power it on, I get as far as "configuring kernel parameters [ok]" and no further. I was wondering if it was something to do with the mouse and keyboard. I have tried these in usb ports at the back and front of the server but can't seem to get any further. My colleague working next to me has an MCS-7825-H2 which booted straight into the configuration wizard. I have 5.1 appliance as previously mentioned, while my colleague has a 5.0 appliance. If you have any suggestions as to why my server won't boot, I would greatly appreciate it. Thank you so much for your help so far.
Tracey
jalston45 Tue, 03/27/2007 - 09:10
Hi I'm curious to know how you made out with this.
thisisshanky Tue, 03/27/2007 - 09:24
Tracey,
since its an I2, it should have 72 gig hard drives. Can you confirm ? Is this a new server or existing server ? If its an appliance, you dont need the CD to boot, because as soon as you fire up the server, it should boot to the install wizard which is imaged into the hard drive of the server.
tracey.marshall Wed, 03/28/2007 - 01:40
Just a quick update. I arrived at my customer's site to discover their existing call manager is on 3.2(3). I have been working on getting this up to 4.1(3) so I can use DMA. I ran the install wizard on the new server out of curiosity and then had a problem browsing with the documented url http://:8080/ccmadmin. Discovered the old url https:///ccmadmin still works though. I have a colleague working alongside me in the lab on another project. He successfully ran the 5.1(1) wizard and imported the DMA file. One thing we found is that there is a bug with ftp so the DMA file has to be imported with sftp. Once I get my server up to 4.1(3), I think it should be straightforward to migrate to 5.1(1).
Thanks to all for your help. I will let you know when I finally have this new server built. Don't hold your breath though!
Tracey
atanasmatev Tue, 10/28/2008 - 02:37
I have the same problem with Cisco Unified Call Manager 5.1. Any suggestions how to fix this? I tried a complete reinstall and I am still getting to that point:
Configuring Kernel Parameters [OK]
