http server enable does not work
Answered Question
Mar 14th, 2007
I cannot seem to set my PIX to allow http access (ie: the web interface). I tried http server enable at the command line and it does not work.
when i type "show http" i see the following:
http server disabled
192.168.8.0 255.255.255 0 inside
and when i type show http server i see:
Usage [no] http <local_ip> [<mask>] [<if_name>]
[no] http server enable
any way to enable this web interface?
Correct Answer by suschoud about 9 years 10 months ago
do not put anything in username block.keep it blank.
the password which you need is the " enable prompt " password.by default it's blank too.
if you have n't set any password on enable prompt ,then keep the username and pass blank and you should be able to access pdm.
if you have setup an " enable password by the command :
enable password ,please use that .
hth,
Sushil
Overall Rating: 4.3 (3 ratings)
suschoud Wed, 03/14/2007 - 09:50
Security506E-6.x# con t
Security506E-6.x(config)#
Security506E-6.x(config)# http server enable
_______________
MAKE SURE YOU ARE IN THE CONFIGURATION MODE
Sushil
mcmcomcisco Wed, 03/14/2007 - 10:00
thanks i managed to get it to work.
Now for another stupid question.
From web interface i now am asked for username and password. where in telnet i only provide a password. All i have is the passwords, i dont know my username! is there a default username i can try ?
Correct Answer
suschoud Wed, 03/14/2007 - 10:03
hth,
Sushil
