Monitor multiple phone for incoming call
Mar 14th, 2007
I want to monitor multiple phone incoming call (retrieve callerID, ...)
I do that with Tapi, but when you configure TSP, it's only for one phone
I can install TSP several times, but ... for 40 phones ...
Are there other solutions ?
I use CCME
ckatene Fri, 03/16/2007 - 16:18
Yes, you can use packet capture to sniff skinny. It works really well, and transparently across CallManager and CallManager Express. You'll need to perform packet decode which is a bit of work, and connect your server to the appropriate SPAN port, of course.
Mike-1985 Fri, 03/23/2007 - 02:00
You can also assign multiple phones (lines) to that specific user in the callmanager.
