Links topology services...
Mar 14th, 2007
When I have discovered with the collector data the equipment leaves the disordered equipment and connections and been able to be placing the equipments of a ordered way but with himself not to be able to move or to readapt the links between equipment (I have made refresh, I have erased the link, etc? Somebody can say to me like moving links????
Joe Clarke Wed, 03/14/2007 - 10:35
I'm not entirely certain what you are asking. If you are trying to clean up the Topology Map, you have the options to re-layout the map in a few different ways under View > Relayout. From there, you can drag devices into the places you want, and select File > Save Layout to save the map.
Links themselves cannot be moved without moving the attached device endpoints. Links cannot be added manually, either.
