1811 wireless config
r-simpson Tue, 03/20/2007 - 10:04
Yes this configuration is right.But using only 54.o mbps allows the connection only at 54 Mbps.In case if the data rates drops on the clients due to interference or weak signal strength clients would be dropped.Try configuring lower basic data rates.
