CSA for ICM/IPCC and SQL backup wizard
Answered Question
Mar 14th, 2007
I have CSA for ICM (version 4.5-1 build 639) installed on all of our ICM servers. It's preventing SQL from doing it's backups to a network share. I shut down CSA and the backups work fine. So, the permissions aren't wrong on the share drive. The backup works fine if the backup is created locally which is not a best practice backup strategy.
Does anyone know of a work around?
Stu
Correct Answer by adignan about 9 years 10 months ago
the managed CSA product will work no problem. you can customize the policy to work with any backup software.
please rate helpful posts.
Overall Rating: 5 (1 ratings)
thomas1 Wed, 03/14/2007 - 14:15
Whoops! I was wrong about being able to backup the logger database locally using the backup wizard. CSA prevents that from happening too. :(
adignan Wed, 03/14/2007 - 19:21
Yeah, I have talked to numerous people at Cisco trying to get the stand-alone CSA policy to allow backup software to run with no luck.
Unfortunately, I no longer install CSA on my IPCC/ICM installations.
please rate helpfuls posts.
thomas1 Thu, 03/15/2007 - 07:30
Do you know if the managed CSA product allows the SQL backup to run or does it behave the same as the stand-alone CSA?
Stu
Correct Answer
adignan Thu, 03/15/2007 - 11:51
