3825 VLAN support for onboard GE interfaces?
Mar 14th, 2007
I've got a 3825 running 12.4(12). Can I place the two onboard GE interfaces (GE0/0 and GE0/1) into a VLAN and assign an IP address to that interface? It looks like no, but I haven't been able to find a definitive answer.
I can get into the VLAN database, but the regular IOS VLAN commands don't work (e.g., int vlan 100).
Are VLANs only supported on the 3825 with the EtherSwitch modules?
--Mike
Overall Rating: 5 (1 ratings)
Amit Singh Wed, 03/14/2007 - 22:14
  • Cisco Employee,
Mike,
You cannot do that. Both the interfaces are layer 3 interfaces and you can make them L2 and assign to a VLAN. You use those interfaces to trunk to some layer 2 switch and does the inter-vlan routing for you.
For example:
router#config t
router(config)#int g0/0
router(config)#no ip address
router(config)#no vlan-id dot1q 300
router(config)#int g0/0.300
router(config)#description ***VLAN300 subinterface***
router(config)#ip address x.x.x.x x.x.x.x
router(config)#encapsulation dot1q 300
router(config)#no shut
router(config)#int g0/0.400
router(config)#description ***VLAN400 subinterface***
router(config)#encapsulation dot1q 400
HTH,please rate if it does.
-amit singh
