show int stat via SNMP
Mar 14th, 2007
Could someone advise me how to get the output of the "show int xxx stat" command via SNMP?
This is for a Cat3750 switch where I would like to get information about the number of process switched and CEF switched packets for SVI ifaces.
Mirek
mzik Thu, 03/15/2007 - 04:52
I know this tool. The problem is that I do not know the SNMP object name. I searched through trying possible names, however, I did not succeed.
deniska2006 Thu, 03/15/2007 - 20:08
Actually, there is "include object descriptions in search" check box, which let you search through description either, not only SNMP object name. (mentioned just in case you didn't notice it)
E.g. search pattern is I found such an object:
cseL3SwitchedTotalOctets
Number of octets in the total packets switched at Layer 3 by this
switching engine
Rolf Fischer Fri, 03/16/2007 - 01:49
if you know exactly the counter-value of the variable you're looking for you could combine net-snmp with grep.
Example:
Core001#show interface fa13/11 stat
FastEthernet13/11
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 0 0 134732 64265937
Searching in enterprises.Cisco for a variable with value 134732 (of cause it works only if the counter doesn't increase too fast):
snmpwalk -v2c -c MyComunity Core001 .1.3.6.1.4.1.9 | grep 134732
enterprises.9.2.2.1.1.30.54 = Counter32: 134732
enterprises.9.2.2.1.1.30.55 = Counter32: 134732
enterprises.9.2.2.1.1.30.56 = Counter32: 134732
enterprises.9.2.2.1.1.31.191 = Counter32: 134732
deniska2006 Fri, 03/16/2007 - 02:14
Be aware of such a problem...
Cisco for some MIB branches requires funny syntax.
e.g.
snmpget -c zsc123@17 10.7.0.2 dot1dTpFdbPor
17 - is Vlan number.
It's impossible to get full dot1dTpFdbPor branch for all vlans using one snmp request. If you have 10 VLANs you have to make 10 request with different community values after @ sign.
The request without @VLAN_NUMBER in community
snmpwalk -c zsc123 10.7.0.2 dot1dTpFdbPor
returns results for VLAN1 only
TO CISCO SYSTEMS:
WHY THERES NO INFO ABOUT THAT IN SNMP MIB BROWSER TOOL ?????!!!!!
Rolf Fischer Fri, 03/16/2007 - 02:28
@deniska2006: Right, I forgot mentioning this funny behavior/syntax. As far as I know it's only relevant for Bridge-MIBs. The variable searched by mzik doesn't sound like being stored in Brigde-MIB.
