Policy Based Routing
Mar 14th, 2007
Hello All,
On my internet router I have 2 Fa interfaces and 1 serial. Fa0/0 is connected to my internal network. S0/0/0 is connected to one ISP. Fa0/1 is conencted to a second ISP. I would like all my HTTP traffic (Web Browsing) to go through Fa0/1 to my second ISP whilst the rest of the traffic is run through S0/0/0 to the first ISP. I would like to use Policy Based Routing to do this for my Fa0/1 interface.
I have configured it but am still unable to access the internet via Fa0/1 to ISP2
Here are the configs that I have:
interface FastEthernet0/0
description Link to DMZ
ip address 202.x.x.33 255.255.255.240
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip route-cache flow
ip policy route-map ISP2
ip nat inside
speed auto
full-duplex
no cdp enable
interface FastEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat pool ISP2_POOL 192.168.1.10 192.168.1.20 prefix-length 24
ip nat inside source list 10 pool ISP2_POOL
access-list 1 permit 202.x.126.38
access-list 10 permit 202.x.126.38
route-map ISP2 permit 10
match ip address 1
set interface FastEthernet0/1
set ip next-hop 192.168.1.1
Any help would be greatly appreciated as I am being given a really short timeline to get this done.
Thanks.
Tim.
Richard Burts Wed, 03/14/2007 - 15:23
Tim
Is the traffic coming from source address 202.62.126.38? That is the only address that your route map and access list will send out the other interface.
Also I am not sure why you are using both:
and
What happens if you remove the set interface and use only set ip next-hop?
Rick
ttuisawau Wed, 03/14/2007 - 15:47
Rick,
Yes. The traffic is coming from source address 202.62.126.38.
I will try to remove the set interface fa0/1 and only use the set ip next-hop.
Will keep you updated.
Tim.
royalblues Sun, 03/18/2007 - 01:08
Tim,
Do you own the public LAN ip pool i.e is it assigned to you by some body like the ARIN/APNIC
If the public lan pool is given by an ISP, then it will most probably be rejected by the other ISP.
Also i do not understand why you are Natting a public ip to a private IP and sending across, unless your ISP is again Natting it.
A brief topology would help
HTH, rate if it does
Narayan
ttuisawau Mon, 03/19/2007 - 14:39
Hello Narayan,
We do not own a public ip pool. The public IP's that we use was given to us by our ISP (ISP1).
We are NATTing a public IP to a private IP before sending to ISP2 who then Natt's it again to their public IP.
We have all HTTP traffic going through the interface fa0/1 connected to ISP2 and all other traffic eg. email going through the serial interface to ISP1.
Topology would be somthing like this:
ISP1--publicIP--s0 ExtRouter fa0/1--NAT--ISP2
fa0/0 of the ExtRouter is linked to our internal network. Fa0/0 has a public IP that is being Natted to a private IP for all HTTP traffic which are directed to ISP2 whilst all other traffic goes via s0.
Hope this helps in understanding my problem.
Thanks.
Tim.
