IPSec tunnel on Router sourced from loopback
Answered Question
Mar 14th, 2007
Is it possible to source a IPSec VPN tunnel on a router from the loopback interface? If so how?
Correct Answer by Kamal Malhotra about 9 years 11 months ago
Yes it is possible. The command is :
crypto map local-address loopback
Please make sure that the loopback interface has a public IP that is reachable.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tsec_r/sec_c3ht.htm#wp1274324
HTH,
*Please rate if it helps,
Kamal
Overall Rating: 4 (1 ratings)
