IPCCX 4.04sr1 - How do I removed users from hist reports?
Mar 14th, 2007
I tried removing them from CCM > Global directory > "RMUser" via device assn so thought that they should not show up in IPCC admin as "resources" but they still do which imply that they will still be in hist reports. Basically, I want them removed altogether as resources. Thx
lpezj Thu, 03/15/2007 - 01:15
I think that you must go to the user that you want to remove from RMCM in the CallManager user configuration and uncheck the 'ICD Ext' field.
When you do that the user will desapear from 'Resources' but the user continues available in the Historicals Reports. In this case you can not delete because they are statistics that the system stores and it would be no coherent to delete the statistics that could afect to the skills or CSQ performance.
Hope this helps,
Juan Luis
(Please, rate helpful posts)
