Memory Allocation Failed
Mar 14th, 2007
I have an 1821 router with VPN configured between two sites. On one of the routers i keep getting messages in Log file - "critical memory allocation of 65548 bytes failed from 0x400C615C, alignmet 32. When I do a show buffers the normal buffers, 1548 bytes, shows 1251600 hits, 1307865 misses, 93615 failures. The FE 0/0 also shows lots of misses. The FE 0/0 is the internal LAN. On both routers for FE 0/1 (outside) interface I have put crypto ipsec df-bit clear. Any ideas why I am getting these failures.
Overall Rating: 5 (1 ratings)
scottmac Wed, 03/14/2007 - 20:06
If they go away for a while after reloading (rebooting) the router, then t's likely to be a memory leak.
What flavor & version of IOS are you running?
Let us know
Good Luck
ednelson Thu, 03/15/2007 - 15:28
Its a 2811 router/fw
IOS 12.4(3e)
After reload problem shows up 10 minute later. Show memory always says there is a bunch of free memory.
any ideas?
scottmac Thu, 03/15/2007 - 17:48
Total memory doesn't really tell the story. You need to look at the "Largest Fragment" listing.
As an example (and *not* reality), let's say the router says you have 32M of available memory total, the Largest Fragment is 500K.
When the router tries to run a process that requires more than 500K, you'll get an "Out of Memory" error (or probably a "MALLOC XXXXXX" error - MALLOC is programmer-speak for "Memory Allocation").
When possible, reload the router (reboot) ... and as soon as possible, start an ASCII capture on your terminal emulator and start doing some "Show Memory Summary (sh mem sum) ... keep your eye on the Largest Fragment listing (the top ~3-4 lines of output)and see if it drops rapidly. You may have a corrupt IOS or other failure that doesn't return the memory back into the pool properly (a memory leak).
It may also be helpful to track some "show process and / or sh proc cpu" to see if there is / what is the process that's sucking up your ram.
BTW: I checked the software advidsor: 12.4(3e) is a defarral.
Table Of Affected Software And Replacement Solution
OS Type
Software Affected IOS 12.4(3e)all Platforms
Software Solution Version(s) 12.4(3f) all Platforms
Software(s) Availability (mm/dd/yyyy)
12.4(3f) is the minimum recommended fix.
Good Luck
hoogen_82 Fri, 03/16/2007 - 01:17
You need to get your router upgraded. Post your show version from the router.
ednelson Fri, 03/16/2007 - 17:05
Thanks for all the help.
I updated the IOS to 12.4(13a) and the problem went away.
