Joe Clarke Thu, 03/15/2007 - 08:18
Syslog forwarding is not something that is easily doable in LMS. It would be better to either configure multiple syslog destinations on your devices, or send syslog messages to a syslog relay that can then send them to multiple servers.
Paul Williams Fri, 03/16/2007 - 02:07
I'll offer this but I am not sure if the same applies to LMS2.2 (We are using 2.5 at the moment).
The way I have done this is to use Notification Services in the Device Fault Manager (DFM). Under Notification Groups simply add a group and the select the devices you want to forward the messages from. When you have completete the creation of the group go into the Syslog Notification and then add a new syslog notification subscription and enter the details of the syslog server that you want to receive the messages.
As I said, this may be completely irrelevant on LMS 2.2.
