Observe the packet drop for file transfer application only, not to other protocal. there is no limitation setting on the routers, anyone encounter the same problem before?
Do you mean your router(s) are dropping FTP packets only? All Ftp packets or only some? Can you post your config? Maybe you have some ACL that is causing the problem?
Learn, share, save
